Setup for slots
I cut four equally spaced 1/16-in.-wide slots in over two dozen 0.625-in. O.D. 0.437-in.-I.D. electrical connectors using a special setup. This 6-in.-long part had an I.D. depth of 5 in., and slot depths ran to the part I.D.
Jan. 1, 2004
To support the workpiece, I used a 1-in.-diameter piece of aluminum turned to match the part's I.D. (slip fit) and O.D. with clearance for a slotting cutter. Its opposite end has flats for a standard mill vise. The other end of the part rests in an indexing fixture.
I then machined a holder extension out of 5/8-in.-diameter drill rod to accept a carbide grooving tool. A capscrew at the end of the extension secures the grooving tool.
After machining slots on one workpiece, I deburr it, push it through the indexing fixture, and reverse the process to load the next one.
Nils G. Bradley
Westerly, R.I.
