[IMTS Preview] ITW Rocol for Natural-Based Gel Metalworking Lubricant
July 27, 2010
ITW Rocol'sAccu-Lube Gel Paste is a natural-based lubricant. It is environmentally safe and made from renewable resources. This amazingly workable lubricant is ideal for horizontal applications because it won’t run or drip. The gel texture of this ...
ITW Rocol'sAccu-Lube Gel Paste is a natural-based lubricant. It is environmentally safe and made from renewable resources. This amazingly workable lubricant is ideal for horizontal applications because it won’t run or drip. The gel texture of this non-toxic product makes it easy to apply to small and large tools with a soft brush without risk of damaging the tool.
Accu-Lube Gel Paste is designed to eliminate the mess and waste causes by other lubricants. No cleaning is required before heat-treating and it is great for short-run machining, reaming, tapping and drilling. This dark blue gel is a neutral product that does not cause contamination or discoloration of products and is safe for use on all metals. Since it is biodegradable and non-hazardous no special disposal is required.
Accu-Lube Gel Paste is supplied ready to use and is available in 8 oz. jars and 5 gal. pails.
Visit IMTS Booth # W-2135
