Single Profile Thread Mills (SPTM) thread small holes with coarse threads in tough materials — a common mold and valve-industry problem. The tools have a solid-carbide-micrograin substrate with a TiAlN coating.
SPTM tools are multifluted for depths to 3 diameter with reduced tool pressure. Available in a range of pitches, they handle threads such as 5 /8-11 UNC or M20 2.5 and can cut internal as well as external threads.
Scientific Cutting Tools Inc.
Simi Valley, Calif.
sct-usa.com
May | $119,703,248 | 110.0% | November | $116,384,449 | 107.1% |
June | $123,443,633 | 113.6% | December | $121,200,994 | 111.7% |
July | $111,215,159 | 102.1% | January | $126,819,295 | 119.2% |
August | $116,382,313 | 106.8% | February | $130,560,000 | 123.0% |
September | $125,456,973 | 115.4% | March | $154,823,146 | 145.4% |
October | $132,331,224 | 121.3% | April | $142,985,844 | 134.7% |
Drills for aluminum
Sandvik Coromant
Fair Lawn, N.J.
coromant.sandvik.com
Drilling/milling tools
The F4033 face-milling cutter has double-sided square inserts with eight cutting edges. The F4041 shoulder milling cutter has rhombic-shaped indexable inserts with four positive-cutting edges and a 90° approach angle. Reportedly, the cutter prevents steps on machined shoulders to eliminate the need for finishing operations. Positive-cutting angles also provide a soft-cutting action with high feedrates and low-power consumption.
Walter Waukesha
Waukesha, Wis.
walterwaukesha.com
Die /mold copy mills
V500 end mills use two inserts on each cutter, and face mills have from four to nine inserts depending on diameter. Inserts come in two coated grades for carbon and alloy steels, tool and die steels, stainless steels, high-temperature alloys, and more. The VP5040 milling grade is multilayered PVD TiAlN/TiN-coated, and VP5135 is a MTCVD multilayer coated grade of TiN/Al2O3/TiCN for rough milling and poor-machining conditions.
Valenite Inc.
Madison Heights, Mich.
valenite.com
