Swiss quality HSK toolholders from Rego-Fix Tool Corp. (www.rego-fix.com), manufactured per DIN standard 69893, are balanced by design to G2.5 at 25,000 rpm. Compatible with the company's ER and PG collets and Hi-Q balancing rings, the HSK toolholders are for use on the latest generation of CNC milling machines. They are coolant-through capable and available in forms A through F and a variety of sizes.
The toolholders deliver hollow taper accuracy to AT3 tolerances for good spindle-to-holder fit and accuracy. They are made from high tensile strength casehardened steel for low wear and long life.
Cutting Tool Digest
Workholding Rotary Systems
Aug. 7, 2007
Cutting Tool Digest
Walter USA Inc.
July 10, 2007
Cutting Tool Digest
H.B. Rouse & Co.
July 10, 2007
Cutting Tool Digest
Sandvik Coromant
July 10, 2007
Cutting Tool Digest
Metalworking/Metalforming Fluids
July 10, 2007
Cutting Tool Digest
Sumitomo Electric Carbide Inc.
July 10, 2007
