Copy-mill catalog
Oct. 1, 2004
An eight-page, four-color catalog provides comprehensive technical information on ValMill V500 copy mills. The catalog presents drawings and specification tables for end-mill and face-mill-cutter bodies, inserts, and spare parts. Also described are two di
V500 copy mills. The catalog presents drawings and specification tables for end-mill and face-mill-cutter bodies, inserts, and spare parts. Also described are two different coated-carbide grades for use with the copy mills.
Provided technical information permits proper insert indexing, cutting-diameter tolerances, and various applications. Catalog machining guidelines help users adjust for chip thinning due to shallow axial-depths-of-cut and narrow radial-widths-of-cut. Additional technical guidelines are for feedrate calculations, proper ramping angles, and multiaxis operations.
Valenite Inc.
Madison Heights, Mich.
valenite.com
