Iscar Metals Inc. (www.iscarmetals.com) says its Bayo T-Ream reamers with interchangeable carbide heads are best for mass-production industries because of their quick setup and indexing times. The interchangeable design allows one shank to be used for a number of hole diameters and materials. The reaming system is for blind and through holes and applications with cross holes or keyways.
@TXD:The interchangeable heads, with internal coolant holes, have a quick-change bayonet mechanism for applications of H7 hole-tolerance range. A key clamps and releases the bayonet screw that is used to mount the carbide head to the steel shank. Solid carbide and heavy metal shanks are available.
Cutting Tool Digest
Workholding Rotary Systems
Aug. 7, 2007
Cutting Tool Digest
Walter USA Inc.
July 10, 2007
Cutting Tool Digest
H.B. Rouse & Co.
July 10, 2007
Cutting Tool Digest
Sandvik Coromant
July 10, 2007
Cutting Tool Digest
Metalworking/Metalforming Fluids
July 10, 2007
Cutting Tool Digest
Sumitomo Electric Carbide Inc.
July 10, 2007
