Engis Corp., Wheeling, W.Va. (www.engis.com), North American distributors of the Di-Pro polishing/finishing system manufactured by Diprofil in Sweden, says the polishing/finishing system optimizes user efficiency and comfort. It weighs 1.98 lb (0.9 kg), has a maximum speed of 10,000 rpm with a stroke length of 0.023 in. (0.6 mm). The system is ergonomically designed for extended use with a variety of drive systems and includes an integrated air motor, flexible shaft (slip-joint or ball-joint), integrated micromotor and connections for other common micromotors.
Engis says the Di-Pro system works best with Diprofil diamond tools including the DLA, DLE, DLF, DLM and DBE types, and with Diprofil lapping and polishing tools.
Cutting Tool Digest
Workholding Rotary Systems
Aug. 7, 2007
Cutting Tool Digest
Walter USA Inc.
July 10, 2007
Cutting Tool Digest
H.B. Rouse & Co.
July 10, 2007
Cutting Tool Digest
Sandvik Coromant
July 10, 2007
Cutting Tool Digest
Metalworking/Metalforming Fluids
July 10, 2007
Cutting Tool Digest
Sumitomo Electric Carbide Inc.
July 10, 2007
