Rego-Fix (www.rego-fix.com)introduced a new line of tabletop presetters that the company says can be used on the shop floor. The Toolmaster TM10 presetters are tabletop units. With electronic parallel correction, operators can make quick, parallelism corrections at any time without mechanical adjustments. The tool taper rides on needle bearings, which allow debris and dust to pass through. Rego-Fix says that with the presetters' 2-percent taper contact, debris or scratches in the toolholder do not affect measurements.
Cutting Tool Digest
Workholding Rotary Systems
Aug. 7, 2007
Cutting Tool Digest
Walter USA Inc.
July 10, 2007
Cutting Tool Digest
H.B. Rouse & Co.
July 10, 2007
Cutting Tool Digest
Sandvik Coromant
July 10, 2007
Cutting Tool Digest
Metalworking/Metalforming Fluids
July 10, 2007
Cutting Tool Digest
Sumitomo Electric Carbide Inc.
July 10, 2007
