Titex (www.titex.com) says its new VA INOX drills have a four-times-feed speed resulting in an increase in productivity compared with standard cobalt drills for stainless steel. The drills offer process secure machining with an external coolant supply and are suitable for older machines and small batch sizes, as is frequently required in the machining of stainless steel.
The drills generate shorter, more compact chips than conventional drills and are therefore suitable for other materials that have a tendency to create long chips and materials that produce soft-chip properties, such as soft construction steel, soft aluminum alloys, electrolyte copper and soft copper alloys. A short design (DIN 1897) is available that can be used on lathes.
Cutting Tool Digest
Workholding Rotary Systems
Aug. 7, 2007
Cutting Tool Digest
Walter USA Inc.
July 10, 2007
Cutting Tool Digest
H.B. Rouse & Co.
July 10, 2007
Cutting Tool Digest
Sandvik Coromant
July 10, 2007
Cutting Tool Digest
Metalworking/Metalforming Fluids
July 10, 2007
Cutting Tool Digest
Sumitomo Electric Carbide Inc.
July 10, 2007
