NUM AG
The NUMroto X program has been rewritten to allow implementation of demanding requirements for tool grinding and enables use of the latest possibilities and functions of modern computer systems.
New CAM Addresses Computing Advances
Sept. 28, 2023
The NUMroto X program has been rewritten to allow implementation of the latest tool grinding requirements and functions of modern computer systems.
NUM AG reported a “ground up” revision to its NUMroto X CAM program, in line with advances in computer functions and addressing the demanding requirements for tool grinding.
Like the existing solution NUMROTOplus, NUMroto X is also designed as a desktop application and will be available in the same version for use on both the grinding machine and the workstation computer. Concepts such as a multi-user database, process analysis with NUMROTO-3D, and product documentation using NUMROTOdraw will continue to exist with NUMroto X.
During the development of NUMroto X, various development focuses were implemented. Instead of nested dialogs, the user interface relies on scrollable areas that clearly display the numerous parameters. User inputs are immediately evaluated and converted into machining paths, allowing for fast workpiece visualization. This makes it possible to observe the effects of parameter changes in real time. For this purpose, the novel visualization calculates a pixel-precise image for each zoom level, making every detail visible, no matter how small.
In NUMroto X the definition and organization of probing cycles can be recorded in sequences, analogous to grinding operations. In this way, the various probing processes can be clearly displayed and set up by the user. Any number of sequences can be created for the same tool, containing grinding operations, probing and dressing cycles, or both. With the ability to execute other sequences from within sequences, they can be combined in any way, allowing complex manufacturing sequences to be configured while remaining clearly displayed.
For the calculation of machine movements, the kinematics module was implemented with a completely new approach. It offers interesting possibilities, including support for interpolating 6-axis movements. New strategies have been implemented for the transfer movement between two grinding processes, which are not only more efficient but also control the axes more optimally.
When creating a new workpiece, the user is supported by an extensive default value system. If required, the default values can be configured almost arbitrarily by the user himself and adapted to the properties of the tool pallet to be produced.
NUMroto X in its first version will provide the range of functions for the production of complex standard milling cutters. There is a large selection of templates for face, shell, and corner profiles that can be combined as desired to form a tool profile. Just as flexible are the combination of shell cutter, face cutter, and clearance definitions.
Learn more at www.num.com
Latest from New Products
Inovatools Eckerle & Ertel
ATI Industrial Automation
ATI Industrial Automation’s patent-pending MC-50 manual tool changer.
Hamar Laser Instruments
The Hamar Laser Instruments L-703SP compact geometry, laser-based calibration system.
ECM PCB Stator Tech
An rotary electric motor with a PCB stator in place.
