Quality Insulated Tools
May 22, 2008
Hand tools insulated to withstand 10,000 volts of electricity Bondhus Corp. (www.bondhus.com) has introduced a line of high quality insulated tools through its German marketing partner, Felo. The line includes screwdrivers, ...
The line includes screwdrivers, bit drivers and pliers, and each is designed tested and certified to comply with all critical safety standards, including insulation safety testing at 10,000 volts of electricity. The company said VDE tests are performed according to IEC60900, DIN 60900 and VDE 0860 specifications.
