End-of-line gauge offers user-programmable measurement parameters, easy part set-up changes, and 0.1-micron resolution per data point.
A submicron accuracy camshaft inspection gauge is being introduced by Adcole Corp., with a new graphic display that lets operators see the tolerance throughput status in real-time for high-speed production monitoring. The ADCOLE 1310 high-speed camshaft gauge features a new graphic display that lets operators visually monitor throughput with green, yellow, and red plots depicting in-tolerance, reaching control limits, and out-of-tolerance status.
Providing gauge room accuracy on the production floor, this end-of-line gauge offers user-programmable measurement parameters, easy part set-up changes, and 0.1-micron resolution per data point or 3,600 data points per revolution.
Enabling the direct correlation between an audit gauge and production floor, the ADCOLE 1310 high-speed camshaft gauge uses the same technology as all Adcole gauges and can process up to 200 parts-per-hour. It can measure 10 or more parameters including radius, profile, taper, crown, timing angle, diameter, velocity, acceleration, run-out, roundness, and concentricity.
