Accu-Lube (www.rolconorthamerica.com) has introduced a coolant applicator for shops that are interested in launching minimum quantity lubrication (MQL) for near-dry machining.
The Accu-Lube Advantage Applicator’s heavy-duty magnetic base and easy-to-use controls are designed to make it easy to install and operate. Also, its portability is designed to service lubrication needs at shops in which operators move between different machines.
The applicator is available in one-nozzle and two-nozzle models, and is made standard with a 10-oz lubricant reservoir, eight feet of air/ lubrication hose and flexible 12-in. Loc-Line nozzles with independent magnetic mounts.
Latest from Shop Operations
News
Lockheed Offering Security-Focused AI
Dec. 17, 2024
New Products
Rugged Industrial Panel PCs for HMI
Dec. 11, 2024
New Products
Larger Part Cleaning Systems
Dec. 4, 2024
