Crane Beam Tractor Drive
May 22, 2008
Spanco Inc. (www.spanco.com) has released a motorized tractor drive for your bridge crane or trolley hoists. Spanco said its Beam Boss Beam Tractor Drive is the first offering from its new Boss Line of products. The beam tractor ...
The beam tractor drive is available in a range of standard speeds, and has many optional features. It is primarily designed for indoor service.
It can run on an I-beam or wide flange beam with lower flange from 3… in. to 8 in. with a 1 in. thick maximum. It can navigate curves down to a 60 in. radius and is rated for H3/Class “C” service. Hardened flat tread wheels are provided with all drives intended to operate on patented track. Optional features include explosion proof controls, spark resistant wheels, soft start, variable frequency drives, and many more. Call SPANCO with your custom inquiries.
