The cutters are available as a one-piece design (R217.29/R220.29) or as a two-piece Combimaster system, which includes various shank types and lengths with interchangeable cutter heads. The button cutters have round inserts with an octagonal integrated angle to prevent insert rotation and ensure indexing location. When used with the company's new 6-mm round inserts, the cutters provide a maximum axial-cutting depth of 0.118 in. (3 mm).
Seco-Carboloy
Warren, Mich.
carboloy.com
Profiling aluminum cutters
Stellram's 5702 cutters produce high metal-removal rates at speeds to 45,000 rpm for pocketing, slotting, and edge milling in aluminum. They are designed, manufactured, and tested according to ISO Standard 15641 and stocked balanced at G 2.5 at 30,000 rpm.
Cutter diameters range from 0.75 to 1.5 in. and 20 to 40 mm. Inserts are available with radii from 0.079 to 0.236 in. (2 to 6 mm).
Stellram
La Vergne, Tenn.
stellram.com
Diamond drills for tough jobs
Synthetic-diamond-tipped drills from Carter Diamond Tool Corp. are for difficult-to-drill nonferrous materials including aluminum, carbon motor brushes, and nonmetallic materials such as fiberglass, rubber, plastic, and composites. Available in diameters from 1 /8 to 7 /16 in., the drills are resharpenable and custom designed.
Willoughby, Ohio
carterdiamond.com
Abrasive machining for deburring and edge contouring
Turbo-abrasive machining from Turbo-Finish Corp. deburrs and produces edge contours and is well suited for finishing large, complex rotating components. The process, which can be automated, eliminates manual deburring operations. The uniformity and isotropic nature of the edges and surfaces produced improves surface integrity and fatigue resistance of critical components.
Turbo-Finish Corp.
Barre, Mass.
turbofinish.com
New wear-resistant coating
Balzers Inc.
Amherst, N.Y.
balzers.com
High-feed milling cutter
The Twincut Feed, with a three-edge insert design that maximizes chip thinning resulting in feedrates to 400 ipm, runs at chip loads to 0.125 in./tooth. Reportedly, metal-removal rates are 2 to 3 higher than with conventional button cutters.
LMT-Fette
Cleveland
lmtfette.com
