HIWIN CORP., developers of motion control and system technology, will be presenting precision motion control components at IMTS 2022 – booth 134514 – namely its Torque Motor Rotary Table series.
Designed for machine tool OEMs and retrofitters, the TMRT series enables three-axis machine tools to be readily upgraded to 3+1, 3+2, 4+1 or even five-axis capability. High speed, high torque, built-in high-rigidity high-precision bearings, absolute encoders, and a powerful brake system promote excellent acceleration capabilities and high precision when machining complex part geometries.
The HIWIN TMRT series rotary tables incorporate direct-drive torque motors, a design that eliminates any gear reducers, resulting in the high dynamic performance and multi-axis path accuracy. Directly coupled encoders and zero backlash enables tighter part tolerance. Direct drives provide smooth motion, resulting in improved part surface finish.
Also, the TMRT series incorporates integral liquid cooling in the table, ensuring thermal stability even during high duty cycle, high load conditions, yielding consistent part quality.
The TMRT series is compatible with most major CNC brands, making control integration straightforward.
HIWIN Torque Motor Rotary Tables use HIWIN’s torque motor components, which also are available for engineers who prefer to design and build a unique table.
Get more information at www.hiwin.us
