Platinum Tooling
REV s.r.l. manufactures broaching solutions for CNC lathes and machining centers. The tools are ideal for machining simple keyways or internal and external profiles, both teeth and splines.
Broaching with Long Insert Life, High Surface Quality
Sept. 21, 2023
Live tools for lathes are well suited for high production runs, offer easy installation and fast processing time.
PLATINUM TOOLING is now offering REV broaching tools as the exclusive North American distributor. in North America. REV S.r.l., is an Italian developer and manufacturer of broaching solutions for CNC lathes and machining centers, offering long insert life and high surface quality, for machining simple keyways or internal and external profiles, both teeth and splines. Common profiles including square and hexagon are easily achieved and custom profiles are available.
The REV motorized broaching tool is designed for use on live tool lathes. Single machine set-up eliminates the need for secondary operation or outsourcing.
REV tools are well suited for high production runs, offer easy installation, and fast processing time. They are designed for maximum rigidity and offer long tool life, and achieve excellent finishes.
REV static broaching tools are for use on CNC lathes with or without Y-axis. They offer a patented eccentric bushing that eliminates alignment errors for machines without a Y-axis. The tools have a sturdy, two-piece construction and are recommended for smaller runs. They are designed for use in boring bar holders on lathes and for use in collet chucks or Weldon holders on machining centers.
REV tools allow for a wide variety of standard and custom profiles and sizes.
Platinum Tooling is an importer and distributor of live tools, angle heads, Swiss machining products, knurling and marking tools. REV broaching tools complement the Heimatec live tools available from Platinum Tooling representatives and distributors.
Learn more at www.platinumtooling.com
