DILLON MANUFACTURING recently introduced Carbinite, a wear-resistant textured carbide coating that reduces or eliminates slippage on workpieces. By improving the grip for toolholders or chuck jaws, the coating enhances milling performance and can reduce cycle times.
In clamping tests, Carbinite was shown to nearly double the gripping strength at equal clamping force. Using a process called Electro Spark Deposition (ESD), Carbinite can be added to hard or soft jaws after they are milled to customer requirements.
The wear-resistant carbide alloys display exceptional bond strength without annealing or distortion.
This coating is ideal for hard or soft jaws, especially Vise Jaws and Step Jaws used for clamping applications. Learn more at www.dillonmfg.com
