KENNAMETAL has introduced a line of digital-ready fine boring tools, the eBore Fine Boring System, that makes precision adjustment simple and promotes more productive, predictable, and accurate boring. The system consists of cutting units to cover a diameter range from 6 to 1,020 mm (0.236 to 40.157 in.) and an optional digital display that makes precision adjustments as simple as turning a screw.
With the eBore digital device, dialing in a tight bore and losing count of how far the adjustment screw was turned is a thing of the past. With an adjustment accuracy of 0.002 mm (0.00008 in.), the chip and coolant-resistant device contain a glass-scale that keeps track of boring bar movement. Simply snap it in place, turn the boring head´s adjustment screw by the desired amount, and the tool is ready for the next boring operation.
For simplicity, the eBore system comes with Kennametal´s KM quick-change interface and can be easily adapted to HSK, PSC, KM4X, and steep taper spindles.
The eBore product line consists of 4 types of tools, all of them feature through the tool coolant, covering the following diameter range:
• eBore Universal Tool: 6 to 152 mm (0.236 to 5.984 in.)
• eBore Fine Boring Tool: 20 to 205 mm (0.787 to 8.071 in.)
• eBore Bridge Finishing Tool: 200 to 1,020 mm (7.874 to 40.157 in.)
• eBore Twin Cutter Roughing Tool: 19.5 to 1,020 mm (7.677 to 40.157 in.)
Learn more at www.kennametal.com
