A new approach to high-speed machining
March 1, 2004
Shops looking to improve high-speed machining reliability and performance have a new software tool at their disposal.
Mikron's Smart Machining program uses vibration monitoring, thermal control, and remote notification to improve high-speed-machining productivity, quality, and cost-effectiveness.
According to Mikron Bostomatic Corp., Holliston, Mass., its Smart Machining program monitors and records spindle vibrations, automatically compensates for thermal deviations, and includes an operator-support system for optimizing high-speed machining according to workpiece requirements.
Sensors integrated with the spindles of Mikron's high-speed machining center, in addition to software and trackball control, provide subtle, extensive degrees of machining control. In addition, a remote-notification system ensures real-time control from any location for reliable, unattended machining.
"Operators typically feed their programs/input into a machine and, by trial-and-error, hope for the best results," comments Mal Sudhakar, Mikron vice president. "These limitations are eliminated with Smart Machining because machinists access a range of real-time, in-process information."
Two key components of Smart Machining are Intelligent Thermal Control, which adjusts thermal deviation during machining, and the Advanced Process System, which features a built-in vibration sensor in a diagnostic spindle module. The sensor measures vibration levels at the bearings during the milling process, and the diagnostic module records the information. Vibration-limit values can be preset, issuing warnings or even shutdown when levels are exceeded.
Latest from Technology Trends
