Kaeser Compressors (www.kaeser.com) has introduced a new line of compressors that are designed to have a smaller footprint and to operate at reduced noise levels.
The SM AirCenter series of rotary screw compressors feature Kaeser’s proprietary Sigma Profile airend, and are available in 7.5 HP, 10 HP and 15 HP models to produce 16 cfm To 54 cfm of air at pressures that range from 80 psig to 217 psig.
The AirCenter series of compressors are tank-mounted, and have the company’s split cooling air flow design with insulated enclosures that provide the quiet operation. The company said the compressors operate at noise levels as low as 66 dB(A).
Kaeser offers the its AirCenter compressor packages in a range of sizes and configurations with standalone or integral refrigerated dryers and optional filtration packages.
Latest from Leading Indicators
Nov. 26, 2007
Nov. 26, 2007
Nov. 26, 2007
Nov. 26, 2007
