Pinpoint Laser Systems (www.pinlaser.com) has developed a laser alignment tool for precision measuring, machine alignment, calibration, and other industrial applications. The company said CNC cutting and milling equipment, lathes, stamping presses, injection molding machines, extrusion systems, and other production equipment can be checked and aligned with its 2D Microgage.
Correct alignment can improve operating efficiency and reduce downtime for such industrial equipment, the company said. The new Microgage 2D is compact and is designed for easy set-up and use on the factory floor.
Latest from Business Trends
Nov. 26, 2007
Nov. 26, 2007
Nov. 26, 2007
Nov. 26, 2007
Nov. 26, 2007
