Light Metal Machining
Nov. 26, 2007
Alfing Corp. demonstrated its AL 204 multi-spindle machining center for cutting complex, light metal parts in medium to high volumes. As the lead machine in a series, the AL 204 features four spindles with four individually driven quills ...
Alfing Corp. demonstrated its AL 204 multi-spindle machining center for cutting complex, light metal parts in medium to high volumes. As the lead machine in a series, the AL 204 features four spindles with four individually driven quills guided alternately from the top and bottom. The company’s Synchro technology motor spindles deliver maximum drive capacity of 58 kW and maximum torque of 70 Nm.
