Hydraulic Presses and Automation
Various hydraulic press styles, from gap frame and straight-side to die-spotting and forging, with unlimited size and tonnage capabilities, plus turnkey robotic and other product handling solutions.
Aug. 17, 2022
GREENERD PRESS & MACHINE CO. will be highlighting its extensive hydraulic press and automation capabilities at IMTS 2022 – booth 236402. One example of its versatility is a very large, 2500-ton, compression molding press that Greenerd designed and engineered, and now is building as part of a seven-press order involving precisely controlled, 108-in. heated platens
The press features an innovative mold-transfer system that significantly improves the ergonomic and safety dynamics for operators, and reduces the press idle time between cycles.
"To meet the demands of today's challenging applications, we are providing manufacturers with press solutions that are flexible, productive and reliable as well as often being quite large and complex," commented Greenerd CEO Jerry Letendre. "For even greater manufacturing efficiency, we are able to provide our hydraulic press customers with turnkey, state-of-the-art robotic and other product handling solutions.”
Greenerd's hydraulic presses are available in a variety of styles ranging from gap frame and straight-side to die-spotting and forging presses, with unlimited size and tonnage capabilities.
Greenerd is a Tier 1 industrial authorized robot system integrator for FANUC America Corp. automated manufacturing equipment.
At IMTS 2022, application experts and design engineers from Greenerd will be available to discuss specific user applications and press requirements.
Get more information at www.greenerd.com
