ANDANTEX USA will unveil its new generation of high-precision planetary reducers at IMTS 2022 – booth 236016 – building upon EVO 1 (Evolution 1) approach to driving machine tool axes. Andantex is a manufacturer of industrial right angle gearboxes (AnglGear), and a distributor of industrial European power transmission products.
The EVO 1 mechanical gearing system approaches the performance of a linear motor at the lower price of a rack-and-pinion linear axis. Features include high stiffness, zero backlash, and an ultra-minimal transmission error. This new design provides vibration-free motion and an optimal surface finish for the machined part.
Andantex will showcase its first range of redesigned planetary reducers featuring EVO 1 technology — the SRP, KRP, KRPX and DRP Series — all of which are available in current sizes. The new design features the breakthrough technologies that made this range of products a favorite for machine tool builders; small-diameter integral output pinion; huge preloaded tapered roller output bearings helping to create maximum combined (radial, torsional and axial) stiffness; as well as patented zero-backlash DualDRIVE and TwinDRIVE solutions.
In addition to the planetary reducers, IMTS attendees will see other products from the Andantex lineup, including:
- Linear and rotary axis drive systems.
- Two-speed spindle drive gearboxes.
- Automatic lubrication systems.
- Merobel magnetic particle tension control systems.
Learn more at www.andantex.com.
