SCHUNK launched its TENDO Platinum V2 hydraulic toolholder, designed and manufactured in the U.S. and the culmination of more than 40 years of ongoing research and development in hydraulic toolholding technology to bring manufacturers the most advanced direct clamping toolholder in the industry.
With its ergonomic, slim outer profile for easy and comfortable actuation, the TENDO Platinum V2 is specifically designed for direct clamping the tool.
Imbalance correction goes unnoticed and is carefully designed into the body profile. Constructed of durable hardened tool steel, the V2 improves stability, stiffness, and clamping force to give you a toolholder with longer sustained accuracy throughout its life.
The TENDO Original with three rings was developed in 1978 and was the first in the market to feature a run-out/repeat accuracy greater than or equal to 0.003, balance G2.5 25,000 rpm, and no risk of damage when clamped without the tool. Learn more at www.schunk.com
