[IMTS Preview] DMG & Mori Seiki Machine Tools in Joint Exhibition
July 13, 2010
Ten newly developed models will be shown for the first time at IMTS 2010, including the Mori Seiki NHX4000, NLX2500/700 and NVX5000 machines. DMG's highlights will include ULTRASONIC 10, a broad selection of automatic lathes, the DMF 260 linear ...
Ten newly developed models will be shown for the first time at IMTS 2010, including the Mori Seiki NHX4000, NLX2500/700 and NVX5000 machines. DMG's highlights will include ULTRASONIC 10, a broad selection of automatic lathes, the DMF 260 linear traveling column machine and the DMU 50 eco machine.
IMTS visitors will see the diversity of the enhanced Turn Mill portfolio in the exhibition of the new Mori Seiki NT1000SZM, as well as the DMG CTX gamma 2000 TC. The most compact of the NT Series, the Mori Seiki NT1000SZM brings a smaller footprint and price to Turn Mill, while the CTX gamma 2000 TC has longer bed length, high torque spindles and the latest SIEMENS control for a new level of productivity and machining flexibility.
The exhibit will also feature a full line-up of 5-axis machining centers. The DMC125 FD duoBLOCK will also be on display, offering productivity machining with 5 simultaneous milling and turning in one set up. Introduction of the new NLX2500/700 demonstrates the continuous improvement of Mori Seiki’s established lathe series. The new DMF 260 linear-column machining center will also be demonstrated, featuring longer traverse paths in the Y and Z-axis, as well as an optional linear drive in the X-axis or a table variation
The Advanced Technologies will be represented with two machining solutions: the compact 5 -axis machine, 10, for the creation of prostheses in all materials and the LASERTEC 40 for lasering of filigree cavities, engravings or surface structures.
Visit IMTS Booth #S-8900
