The fully integrated 5-axis XR 600 5AX High-Performance machining center from Bridgeport, a member of The Hardinge Group (www.hardinge.com), takes its place as the newest member of the company’s series of XR vertical machining centers.
The rigid bridge-style machine has 45-mm fixed pre-tensioned double-nut cooled ballscrews on all its linear axes and carries a 600-mm-diameter integrated dual-axis rotary table with 150-degree tilt and 5-arc-second accuracy.
News
2025 Outlook for Manufacturing Technology
Jan. 7, 2025
News
More Improvement in US Machine Tool Orders
Nov. 12, 2024
Machining / Cutting
5-Axis Machining for Large Parts
Oct. 16, 2024
