Modular-Based Machine
Sept. 8, 2008
Grob Systems Inc. (www.grobgroup.com), Machine Tool Division, will spotlight the modularbased durability and precision performance of its U.S.-built G350 horizontal machining center. Grob located a slide-mounted spindle module to one side ...
Grob located a slide-mounted spindle module to one side of the machine’s centerline for a precise and stable Z axis with twice the tool rigidity of conventional quill-feed systems, resulting in a 0.00039 in. positional tolerance and 0.00019-in. positional variation.
Michal Bednarek | Dreamstime
