Thermal friction drilling systems from Flowdrill Inc. (www.flowdrill.com) produce perfectly formed collars in malleable metals by using a combination of speed of rotation and pressure to locally heat the material. A Flowdrill thermal friction drill spins and creates heat, which allows it to penetrate and reform displaced material in seconds. Displaced material then forms a collar on the upper side of the workpiece for deeper threads, or a flat-type Flowdrill tool can produce holes without the collar.
News
2025 Outlook for Manufacturing Technology
Jan. 7, 2025
News
More Improvement in US Machine Tool Orders
Nov. 12, 2024
Machining / Cutting
5-Axis Machining for Large Parts
Oct. 16, 2024
