The BO 110 heavy-duty horizontal boring mill from Knuth Machine Tools USA Inc. (www.knuth-usa.com) features a 360-degree rotary table for easy access. The table handles loads to 5,500 lb, and its travels measure 39 in. by 35 in. by 35.25 in., with a spindle-center-to-table range of 0 to 35 in. The machine’s quill, headstock and table can feed in 36 steps from 0.0016 in. to 0.06 in. per revolution depending on spindle rpm.
With a 3-axis DRO, the BO 110 has a spindle diameter of 4.250 in. with variable frequency drive that provides 8 to 1,000 rpm. The spindle feeds a distance of 23.6 in. with an axial thrust of 2,750 lb and torque of 900 ft-lb from a 10-hp motor. There is a facing slide as well with a feed of 7.1 in.
News
2025 Outlook for Manufacturing Technology
Jan. 7, 2025
News
More Improvement in US Machine Tool Orders
Nov. 12, 2024
Machining / Cutting
5-Axis Machining for Large Parts
Oct. 16, 2024
