RUSH MACHINERY will showcase the CNC “Auto-Cut” carbide rod cut-off machine at IMTS 2022 – booth 237233. The “Auto-Cut” can double the production rate for cutting carbide and hardened steel rod when compared with manual cut-off machines. It has easy-to-use CNC controls with a touchscreen operator interface. Parameters can be quickly set for rod diameter and length.
The machine automatically loads and cuts rods from a large capacity magazine. Capacity of the “Auto-Cut” is 0.055-in. (1.4-mm) to 1-9/16-in. (40-mm) diameter carbide rod, up to 16 in. long, and it comes standard with a flood coolant system.
Rush Machinery provides top-quality products and service, including production and support machines for industries that use diamond and CBN wheels and work with carbide and other hard materials.
Machines are available for truing and dressing diamond/CBN wheels; cutting off carbide/HSS rods and tools; cutting, prepointing, and chamfering carbide/HSS rods; chamfering carbide/HSS rods; balancing wheels and tools; grinding PCD tools; filtering grinding oil; and sharpening drills and tools.
Get more info at www.rushmachinery.com
