DN SOLUTIONS (formerly Doosan Machine Tools) will introduce the SVM 5100L at IMTS 2022 – booth 338900. The latest member of a family of vertical machining centers, the SVM 5100L a big brother to the SVM 4100 and sits between the DEM and the DNM series in the DN portfolio. The SVM 5100L incorporates a traditional C-frame design structure that is optimized to provide a solid platform for fast, light duty machining operations.
“The SVM 5100L is another example of DN Solutions filling every niche our customers work in,” according to Jim Shiner, vice president of Sales and Marketing at DN Solutions America. “If you need a vertical machining center with speed to cut lighter materials, you can now choose between different sizes of SVM models. For more robust materials, the DNM line is available.”
Like its smaller sibling, the SVM 5100L’s performance has been optimized to provide shorter cycle times by reducing the acceleration/deceleration times of the XYZ axes and spindle, thereby minimizing non-cutting time. The 25-hp (18.5 kW) motor on the SVM 5100L turns the spindle at a speed of 12,000 r/min which generates 70.5 ft-lbs (95.5 kW) of torque. The X-axis travel is 50 inches (1,270mm); Y and Z-axis travels are 20.1 in. (510 mm) each.
The maximum table capacity is 1,763.7 lbs. (800 kg) and the rapid feedrate is 1,417 ipm (36 m/min).
While it is priced affordably, the SVM 5100L is not a “stripped down to cut costs” model. It is packed with standard features that include a CAT 40 BIG-PLUS spindle system, through-spindle coolant, a double-arm ATC with 30 tools, and a FANUC 0i-Plus control with iHMi touch screen interface.
Get more information at www.dn-solutions.com
