Rush Machinery
The Rush Machinery FC-350W wheel truing and dressing machine.
Wheel Truing and Dressing Machine
June 29, 2022
The system will set the diameter, profile, and sides of wheels without disassembling the wheel pack, plus optional guarding with clear pivoting sections, for easy access.
RUSH MACHINERY’s FC-350W wheel truing and dressing machine will be exhibited at IMTS 2022 – booth 237233 – including optional machine guarding accessories.
The FC-350W is designed for ease and efficiency in truing and dressing of flats, angles, and radii on diamond and CBN single wheels and multiple wheel packs. The FC-350W allows users to dress the diameter, profile, and sides of the wheels without taking the wheel pack apart. The optional guarding has four clear acrylic pivoting sections that allow for easy access. Retrofit may be performed by a Rush service engineer if requested.
Also, the machine is pre-installed with RushVision, a software designed to make truing and dressing easy and customizable. RushVision aids in high-precision, high-tolerance work and truing complex forms and radii up to 2 in. (50 mm.) The software includes drawing templates for most common wheel shapes, and allows users to import from CAD via USB port or networked PC.
Rush Machinery manufactures and services a complete line of production and support machinery for the cutting tool industry: Wheel truing and dressing machines, dynamic balancing systems, carbide rod and hss cut-off machines, chamfering machines, grinding oil filtration systems, polycrystalline tool grinders, drill and tool grinders, as well as tool grinding fixtures.
Get more information at www.rushmachinery.com
