Brush Research Materials
Flexhone Automated Setup 800 5fa3838b46905
The Truth About Abrasive Finishing Tools in CNCs
Nov. 5, 2020
Finishing tools release little to no abrasive grit during use, and the amount generated is comparable to the metal chips, grinding dust, and tool abrasion created during ordinary machining.
New advances in abrasives technology mean that CNC machine operators are able to complete surface finishing simultaneously with other operations, speeding cycle times, improving product quality, and saving on off-line finishing time and costs. As a result, machine shops increasingly turn to abrasive finishing tools that can be integrated easily into CNC machine carousels or tool-holding systems.
However, this leads to inevitable questions about the use of abrasive materials in high-value CNC machining centers. In general, the concern is that “abrasives” – like sandpaper – release large amounts of grit and debris that could clog coolant lines or damage exposed slides or bearings.
“These are very expensive, very accurate machines,” explained Janos Garaczi, president of Delta Machine Co. LLC, a shop that specializes in complex, tight tolerance parts in titanium, nickel alloys, stainless steel, aluminum, plastics, and more exotic alloys. “I wouldn’t do anything to jeopardize the accuracy or lifespan of the equipment.”
In fact, a closer examination of abrasive tools reveals these concerns are largely unfounded. Although “abrasives” often are lumped into the same category, a distinction must be made between abrasives used for aggressive material removal and abrasive finishing tools. Finishing tools release little to no abrasive grit during use, and the amount generated is comparable to the metal chips, grinding dust, and tool abrasion created during ordinary machining.
Even if minimal fine solids are produced, the filtration requirements for abrasive tools are not much different than for machining. Any particulate can be easily removed using inexpensive bag or cartridge filtration systems, according to Jeff Brooks of Filtra Systems, a company specializing in industrial filtration systems including for CNC coolant.
“A disposable media, vacuum filter or pressure filter is the most cost-effective option for the end user for filtration that will achieve the high clarity levels required,” explained Brooks.
“For fine honing work, I would recommend a 20-micron bag, or cartridge filter at minimum, to catch any fine solids and adequately protect the tool and the sump pump, and keep the coolant ports from clogging,” said Chris Erato, director of sales at Oberlin Filter, another supplier of separation filtration for CNC coolant systems.
For CNC operators interested in a fully automated pressure filtration systems, there are units that eliminate the need to remove bags or clean magnetic separators, to maximize production uptime.
On the shop floor – According to Tim Urano, quality manager at Wolfram Manufacturing, any additional cost for filtration related to the use of abrasive tools is so negligible that it is “not really a consideration because filtration systems are already required to remove particulate from the coolant generated during the machining process itself.”
At his shop, that includes scale, grit, and rust created by cutting through raw stock. Lately, Wolfram Manufacturing is machining more 3D parts made of Inconel, which can release into the coolant fine metal powder that is not fully sintered.
As for abrasive tools, Urano said Wolfram Manufacturing has “never, ever experienced any problems caused by abrasives in our cutting fluids.”
For the past eight years, the machine shop has incorporated the Flex-Hone in all CNC machines from Los Angeles-based Brush Research Manufacturing (BRM), for cross-hole deburring and surface finishing. Characterized by the small, abrasive globules that are permanently mounted to flexible filaments, the product is a flexible, low-cost tool used for sophisticated surfacing, deburring, and edge-blending.
Removal of burrs and sharp edges in cross-drilled holes and other difficult-to-access areas, such as undercuts, grooves, slots, or internal holes, is critical. Failing to remove burrs can cause blockages or create turbulence in the flow of fluids, lubricants, and gases through critical passages.
“On a given part, we might deploy two to three different-sized Flex-Hones, depending on the number of cross-port intersections and different hole sizes,” Urano related.
The Flex-Hones are added to the tool carousel and are used daily, usually several times an hour, on some of the shop’s highest-volume parts.
“The volume of abrasives that could even possibly come off of the Flex-Hone is insignificant compared to the rest of the particulate that gets into the coolant,” Urano explained.
At Delta Machine in Gardena, Calif., automated crosshole deburring is also integrated into the CNC machining process. “When you use the Flex-Hone for deburring, all you are doing is removing the burr. It doesn’t create much dust,” Garaczi added. “So, for me, any grit or dust released is zero concern. It is not like we are grinding inside the machine with powder everywhere; this is not the same at all.”
Abrasive nylon filaments – For Eric Sun, founder of Orange Vise Co. in Orange County, Calif., even cutting tools like carbide drills and end mills can create debris that must be filtered from the coolant.
“Some machine shops might say, ‘I don’t use any abrasives in my process; therefore, my machine is completely free of all particulate matter,’ but that is not the case,” Sun said. “Even cutting tools can wear down and the carbide can come loose and get into the coolant.”
Although Orange Vise is a contract manufacturer, the company primarily machines vises and quick-change fixturing components used in CNC machines out of aluminum, steel, and cast iron. It uses four Mori Seiki NHX4000 high-speed horizontal machining centers and two vertical machining centers.
Sun noted that many of the vises are made of cast iron with selectively hardened surfaces. To match the surface finish of the hardened surfaces, Orange Vise uses BRM’s NamPower abrasive disc brushes.
Composed of flexible abrasive nylon filaments bonded to a fiber-reinforced thermoplastic base, the NamPower abrasive disc brushes contain a novel combination of ceramic and silicon-carbide abrasive. The abrasive filaments work like flexible files, conforming to part contours, wiping and filing across part edges and surfaces to deliver maximum burr removal rates along with an ideal surface finish. Other common uses are edge blending, part cleaning, and rust removal.
To complete the surface finishing operation, abrasive nylon brushes are installed in the tool-loading system of each CNC machine. Although abrasive grit is involved, Sun said the NamPower brush is a “different type of abrasive” because it is essentially “self-sharpening.” Due to its linear construction, sharp new grains constantly come in contact with the work surface and wear off exposing fresh cutting particles.
“We have used the NamPower abrasive nylon brushes daily for six years. During that time, we have had no issues with any sort of particulate or grit getting into any critical surfaces,” added Sun. “In our experience, any small amount of grit created is a non-issue.”
Jeff Elliott is a Torrance, CA-based technical writer.
Jeff Elliott
Jeff Elliott is a Torrance, Calif.-based technical writer.  He has researched and written about industrial technologies and issues for the past 20 years.
Michal Bednarek | Dreamstime
