Techniks Inc. (www.techniksusa.com) has introduced a toolholding fixture that mounts to the side of a tool cart or bench and secures toolholders for changing cutting tools, collets, and pull studs. The NT S Tightening Fixture is designed to work with: CAT , BT, ISO, and HSK toolholders. Toolholders are placed in the NTS fixture and the locking screw knob is tightened to engage the drive slot or wrench flats – depending on the toolholder – to secure the toolholder. Techniks recommends using a torque wrench and tightening to specifications to insure safety and improve cutting tool life.
Latest from Cutting Tools
New Products
High-Pressure Coolant for Round Inserts
Dec. 18, 2024
News
Big Drop in Cutting Tool Demand
Nov. 22, 2024
New Products
New Grade for Indexable Steel Milling
Nov. 13, 2024
