Primary Cutter LLC has introduced the Supermill For Aluminum line of carbide end mills with a geometry designed for aluminum applications.
The tools have sharp corners, full eccentric relief and a diamond-like carbon coating for fast stock removal and long tool life. The end mills are available in three-flute, variablepitch design and with 45-degree helix angle, and are offered in 0.1875 in. to 1.00 in. sizes, and long and extra long in diameters of 0.250 in. through 1.00 in.
Latest from Cutting Tools
New Products
Digital Axial Boring Heads
Jan. 8, 2025
New Products
High-Pressure Coolant for Round Inserts
Dec. 18, 2024
News
Big Drop in Cutting Tool Demand
Nov. 22, 2024
New Products
New Grade for Indexable Steel Milling
Nov. 13, 2024
