Onsrud Cutter (www.Onsrud.com) said it has developed a line of tools that are capable of running at high spindle speeds while providing good tool life to solve the problem of cutting stainless steel on a high-speed CNC router.
The combination of cutting geometry and coating allows stainless steel to be routed for sign, exhibit, and general sheet applications.
The solid carbide tools are available in 0.125-in., 0.1875-in., 0.250-in. and 0.375-in. diameters and can be run at spindle speeds from 6,000 rpm to 18,000 rpm.
Latest from Cutting Tools
New Products
Digital Axial Boring Heads
Jan. 8, 2025
New Products
High-Pressure Coolant for Round Inserts
Dec. 18, 2024
News
Big Drop in Cutting Tool Demand
Nov. 22, 2024
New Products
New Grade for Indexable Steel Milling
Nov. 13, 2024
