IBAG North America (www.ibagnorthamerica.com) said its new air-cooled “Plug and Go” HFK 95 S40 high-speed spindles are designed for fast and easy setup in vertical or horizontal machining centers. The spindles are rated at 4 hp peak power and 2.6 hp continuous duty, and provide infinitely variable speeds to 42,000 rpm.
HFK 95 “Plug and Go” spindles can be adapted automatically through Automatic Tool Change (ATC) (Option Q) from the tool magazine into the main spindle of the machining center. This is possible through the automatic coupling for electricity and pneumatics. With air cooling and grease lubrication, only a small supply unit with integrated converter and a pressurized air feed are required.
Latest from Cutting Tools
New Products
Digital Axial Boring Heads
Jan. 8, 2025
New Products
High-Pressure Coolant for Round Inserts
Dec. 18, 2024
News
Big Drop in Cutting Tool Demand
Nov. 22, 2024
New Products
New Grade for Indexable Steel Milling
Nov. 13, 2024
