Diamond coatings are grown in a vacuum chamber using feed gases of hydrogen and methane. Usually the gases are fed into the chamber in a 50-to-1 mix, with hydrogen being the predominant gas. A high-temperature element in the chamber causes the deposition process to take place. For example, sp3 Inc. (www.sp3inc.com) uses fine filaments energized to about 2,200 C to break down the methane into carbon and hydrogen. The carbon atoms then nucleate and grow tiny crystals of diamond and, in time, these tiny crystals grow into a continuous diamond film. Diamond grows slowly, about 0.5 to 1.0 micron per hour. Growing a 40-micron film on inserts can take almost two days whereas most round tools are coated overnight.
Latest from Cutting Tools
New Products
Digital Axial Boring Heads
Jan. 8, 2025
New Products
High-Pressure Coolant for Round Inserts
Dec. 18, 2024
News
Big Drop in Cutting Tool Demand
Nov. 22, 2024
New Products
New Grade for Indexable Steel Milling
Nov. 13, 2024
