Sandvik Coromant introduced a new range of Coromant Capto machine adapted clamping units (MACU) for lathe machines.
The new Capto products are designed for both turning and milling applications. They provide the flexibility to change quickly from one system to another, and to channel high-pressure coolant from the latest CoroTurn HP cutting heads to reduce temperatures and improve chip control.
The machine adapted clamping units are available for Mazak, Mori Seiki, Nakamura Tome and Okuma machines.
Latest from Cutting Tools
New Products
Digital Axial Boring Heads
Jan. 8, 2025
New Products
High-Pressure Coolant for Round Inserts
Dec. 18, 2024
News
Big Drop in Cutting Tool Demand
Nov. 22, 2024
New Products
New Grade for Indexable Steel Milling
Nov. 13, 2024
