BIG Kaiser Precision Tooling Inc. has expanded its Phoenix drill from six-times-diameter to include three-times-diameter and 12-times-diameter sizes. The drills are available in diameters from1 mm to 12.7 mm, in 0.1-mm increments, with coolantthrough from 2.5-mm diameter and a Helica coating. Special dimensions are available upon request.
The Phoenix drill’s high-performance flute and point geometry assure low cutting forces and optimum chip control. Internal coolant makes the drill good for cutting extra-hard materials such as steel, stainless steel, cast iron and titanium. Its ultrafine grain composition delivers high wear resistance and toughness for superior speeds and feeds.
Latest from Cutting Tools
New Products
High-Pressure Coolant for Round Inserts
Dec. 18, 2024
News
Big Drop in Cutting Tool Demand
Nov. 22, 2024
New Products
New Grade for Indexable Steel Milling
Nov. 13, 2024
