The new Exocarb Aero Rougher from OSG Tap & Die is designed for maximum metal removal of exotic materials such as stainless steel, titanium, and Inconel. The combination of the shallow profile serration and the 45-degree helix provides a smooth surface finish. Serrations on the cutting edge reduce friction, thereby generating less heat and requiring less horsepower than standard or variable helix carbide end mills. The tool is available in 0.250-in. to 1-in. diameters and with corner radii from 0.030 in. to 0.190 in.
Latest from Cutting Tools
New Products
Digital Axial Boring Heads
Jan. 8, 2025
New Products
High-Pressure Coolant for Round Inserts
Dec. 18, 2024
News
Big Drop in Cutting Tool Demand
Nov. 22, 2024
New Products
New Grade for Indexable Steel Milling
Nov. 13, 2024
