Heavy axial or radial forces, intermittent cuts and off-center applications may cause the workpiece to push back into the collet, spin, slip or walk out of the collet. Serrations located in the gripping area of the collet will add additional gripping power using the same draw bar pressure. Serrations also provide maximum contact area when gripping irregular surfaces such as hot-rolled and cast bars, or cast or forged parts.
Latest from Cutting Tools
New Products
High-Pressure Coolant for Round Inserts
Dec. 18, 2024
News
Big Drop in Cutting Tool Demand
Nov. 22, 2024
New Products
New Grade for Indexable Steel Milling
Nov. 13, 2024
