GenSwiss
GenSwiss Industries guide bushings and collets.
Hydraulically Actuated Clamping Toolholders
July 27, 2022
A new line of toolholders achieves high accuracy thanks to a quick-clamping mechanism capable of keeping drill and boring bar shanks within 0.00004-inch total runout.
GENSWISS INDUSTRIES, a Swiss machine tooling manufacturer and provider, will present several new offerings at IMTS 2022 – booth 432356 – including GenGrip hydraulically actuated clamping tool holders and Signature series collets and guide bushings.
The GenGrip line provides high-accuracy tool holding by employing a quick-clamping hydraulic mechanism capable of keeping drill and boring bar shanks within 0.00004-inch total runout. This is optimal for holding small-diameter drills, gun drills and precision boring bars.
Hydraulic clamping is activated from the front or rear of the tool block with a T-handle hex key. This provides a safe way to change tools by keeping hands away from dangerous components during positioning.
GenSwiss Signature collets and guide bushings provide stock material with excellent stability, which results in better cutting performance. Available for major machine models (including Star, Citizen, Tornos, and Tsugami) GenSwiss Signature series collets and guide bushings allow operators to create complex parts accurately and precisely while increasing productivity by reducing cycle times. Operators can minimize the risk of error in their runs by giving the stock material the support that it needs.
Get more info at www.genswiss.com
