FANUC America
Np Fanuc Qssrg Code 6077b7cf94193
Simplified Robot and CNC Integration
April 15, 2021
The Quick and Simple Startup of Robotization platform allows operators and machine tool builders to program robots easily through the CNC in ISO standard G-code format.
For more efficient operations, FANUC CNCs now have the ability to control connected FANUC robots providing machine tending or other assistance through FANUC’s Quick and Simple Startup of Robotization (QSSR.)
The QSSR is a complete package that simplifies the connection of a FANUC robot to a FANUC controlled machine tool. The QSSR G-code feature allows operators and machine tool builders to program robots easily through the CNC in ISO standard G-code format. Those unfamiliar with robotic programming language will no longer require additional training or specialists because the programming can be performed with G-codes. Reliance on a separate teach pendant for the robot is also greatly reduced with the capability of robotic programming and operation through the CNC user interface.
FANUC’s QSSR not only makes connecting a FANUC robot through a high-speed Ethernet cable to a machine tool easy but also simplifies the setup, programming, and operation.
The QSSR G-code feature is available on FANUC CNC Series Oi-F, Oi-F Plus, 30i-B, and 30i-B Plus.
Learn more at www.fanucamerica.com
Siemens Digital Industries
Wintriss Controls Group
ABB Robotics
ABB AppStudio software tool.
