Balancing |
Errant Performer Or Scapegoat Spindles get blamed for a lot of machining problems but, in many cases, the spindle is not the root cause of the problem. Crashes and heavy cuts can eventually lead to a need for a rebuild, and, when quality problems crop up, a tool is needed that can identify quickly whether it is time to change-out the spindle, or if the cause of the problem is a process elsewhere in the machine system or beyond.
Toolholder Balancer For use with any rotary-transfer machine from Hydromat Inc., St. Louis, (www.hydromat.com), the Harmonic 200 toolholder balancer adds two eccentric rings or removes imperfections to reduce or offset imbalance to make any company toolholder dynamically stable. .
Toolholders with Improved Balance Rego-Fix (www.rego-fix.com) says its Q- #49, #47 and #50 system of steep-taper and HSK high-speed toolholders have improved balance as a result of a low-distortion hardening process and precision balancing. The steep-taper toolholders are pre-balanced to G2.5 at 22,000 rpm, while HSK toolholders reach G2.5 at 25,000 rpm.
Toolholder Boosts Reamer Life A new toolholder, which consists of only a head, holder, and differential screw, reportedly increases tool life, improves accuracy, and delivers higher speeds and feeds than conventional taper-flange-style toolholders. The Head Fitting System (HFS) uses the screw to draw in the taper to make face contact, providing exceptionally low runout.
Rotary-Table Imbalance-Sensor Imbalance conditions in rotary B-axis tables are detected by Balance Sensor technology developed by Cincinnati Machine (www.cincinnatilamb.com). The software is designed to sense rotary table, fixture and part imbalance using direct feedback from machine controllers.
Plant Seals Up Spindle Contamination Problem An Indianapolis automotive plant was experiencing spindle failures in a transfer line that produced power-steering components. Four identical spindles had bearing-contamination problems caused by high volumes of coolant that was used within a confined, guarded work envelope. These spindles failed within six months, and the plant needed a remedy.
Detecting Small-Drill Distress Conventional acoustical sensors for detecting and monitoring small-tool wear and breakage are limited by their sensitivity and ability to overcome background, no-load noise. For example, drills of 0.12-in. diameter on a 15-kW spindle or 0.06-in. diameter on a 3.5-kW spindle are about as small as can be reliably monitored with conventional tool-monitoring systems.
Heating/Cooling Shrinkfit Tooling T.M. Smith's (www.tmsmith.com) G5 shrinkfit tabletop induction-heating machine provides integrated refrigerant cooling and a three-station rotary toolholder table.
Anti-Vibration Adaptor For Milling With Long Overhangs The Coromant Capto Damped Milling Adaptor, recently introduced by Sandvik Coromant (www.coromant.sandvik.com), reduces vibration while milling with long overhangs. The product's sophisticated dampening mechanism eliminates any perceptible vibration caused by the cutting forces applied while end milling or profile milling with overhangs up to seven times the coupling diameter.
Modular Toolholding System Sandvik Coromant designed its Capto polygon-shaped modular tooling system for use with turning and milling centers, and machining centers. The tooling system has a clamping system with an improved amplifier and gas spring that the company says maintains a high clamping force up to five times longer than conventional spring packages at high spindle speeds. The toolholder operates without changing the properties of balanced spindles of high-and low-speed machines. (www.coromant.sandvik.com)
Featured Advertiser |
Makino— a leading manufacturer of horizontal and vertical machining centers and EDM machines — has announced a new series of online Webinars. Designed for shops of all types and sizes, the seminars are free to anyone who registers. The planned seminars are intended for shops in the automotive, aerospace, medical product and die and mold industries. In addition to metal cutting and die/mold, the seminars will cover new technologies, such as micromachining. Mark Rentschler, marketing manager, says, "Online seminars allow anyone with an Internet connection to attend without losing a day of work." The seminars concentrate on shop efficiency, lean manufacturing, asset utilization, machine tool integration and automation, machine tool technologies, and metal cutting processes. Makino's application engineers, product managers and guest speakers will give presentations. Click here for more info on upcoming seminars and registration information.
American Machinist Sponsors Machine Shop Workshop 2007 |
Upcoming Webcast Series |
- Best Kept Secrets to Improving Part Quality -- September 12, 2007 2:00 PM ET
Practical Machinist Metalworking Forum |
AMERICAN MACHINIST DIGITAL EDITION |
Now you can get the latest edition of American Machinist delivered directly to your PC. Click here to learn more about the digital edition. |
Welding Webcast Series |
- ERP for Gases: On the Edge of Enough - July 18, 2007 @ 2:00 PM ET
- Best Practices in Electrode Selection: Maximum Profit Starts With the Process - September 25, 2007 @ 2:00 PM ET
