www.imts.com IMTS 2008 can help reduce your manufacturing costs. You'll see faster, more precise machines; cutting tools to process virtually any material; finishing technologies; automation systems; quality instruments and manufacturing software. You'll see how to reduce cycle times and increase productivity. For more information, go to www.imts.com
Articles |
In-House CNC Tool Grinding Can Work For You |
There are several reasons that shops should consider CNC tool grinding, including that it provides the ability to produce high-quality, long-lasting tools and allows for flexibility and control of the process while saving a ton of money. But, because in-house tool grinding is not part of shop's core competency, careful analysis is necessary to be sure in-house grinding can be justified. |
Superabrasive Wheels For External O.D. Grinding |
In the past, many manufacturers were wary of upgrading to superabrasives for their external grinding applications due to the relatively high cost of these products as compared with their conventional counterparts. Manufacturers who considered but rejected the idea of using superabrasive wheels in the past for external O.D. grinding now have good reason to reconsider. One manufacturer's early focus on small internal grinding wheels made it necessary for the company to pay close attention to the consistency and quality of superabrasive materials and bonding system performance. Now this expertise has been transferred to large wheels, and users are experiencing quantifiable cost/ performance advantages not only versus conventional wheels but also competitive superabrasive products. Users are reporting 20 percent faster cycle times and/or cost per part reductions to 30 percent. |
Low-Foaming Coolant |
If coolant foaming is a problem, check out this recently introduced universal synthetic machining coolant. It is designed for a range of applications including grinding, sawing, tapping, drilling, turning and milling. Not only is the fluid low foaming with a high level of lubricity, but it also provides a high level of rust protection. |
New Disc-Milling Inserts |
Two new inserts have been added to a family of disc milling products for a variety of slotting, facing, circular interpolation, and circlip grooving applications in any material. Both have up to four cutting edges per insert and offer wiper flats for applications requiring a high-quality surface finish. |
Vibration Damping Toolholders |
A new line of toolholders are for rough milling applications and provide for easy operation, good vibration dampening characteristics, and an attractive cost-performance ratio. Due to the high radial stiffness and vibration dampening characteristics of the toolholders, the surface quality of workpieces is improved while noise is reduced. Less vibration of the cutting tool means increased tool life and protection of the machine spindle resulting in workpiece finishes without chatter marks. |
Hot Products |
Sponsored by ATI |
ATI Industrial Automation has released VersaFinishTM, an Axially-Compliant Finishing Tool suitable for a multitude of robotic and automated material finishing operations. VersaFinish is a robust, low-speed, high-torque air tool with an axially-floating spindle that uses many types of media including, abrasive and wire brushes, sanding disks, polishing points, chamfering tools and more.
Visit our web site www.ati-ia.com.
Practical Machinist Metalworking Forum |
Exchange ideas with others in the industry |
Join in! Visit Practical Machinist, the leading online discussion forum for the metalworking community. |
Complex Casting Or Involved Blueprint |
"Machining from a model is one thing. But to have to spend time creating a complex part is another." |
Powder Coating Thickness? |
"Does anyone know how thick a layer of powder coating is?" |
"Making Things Better" |
"The US Congress on competition from Japan and others. Old but interesting read." |
Digital Edition |
AM Digital Edition Available |
Now you can get the latest edition of American Machinist delivered directly to your PC. Learn more about the digital edition. |
