Rotary-screw compressors
Sept. 1, 2004
The 20, 25, and 30-hp AS rotary-screw compressors feature the manufacturer's Sigma Profile air end and deliver 59 to 124 cfm along with pressures from 80 to 217 psig. The compressors' split cooling air-flow designs reportedly reduce noise and improve cool
The 20, 25, and 30-hp AS rotary-screw compressors feature the manufacturer's Sigma Profile air end and deliver 59 to 124 cfm along with pressures from 80 to 217 psig. The compressors' split cooling air-flow designs reportedly reduce noise and improve cooling. Maintenance features include automatic-belt-tension and quick-fluid-change devices.
Kaeser Compressors
Fredericksburg, Va.
kaeser.com
