Grinder removes weld beads
Dec. 1, 2004
Dynabrade's 4 1/2-in.-diameter depressed-center wheel grinder features a 12,000-rpm, 1-hp air motor for cleaning metal before welding and removing weld beads afterwards. This grinder has a safetylock throttle and grip-traction side handle that increase sa
Dynabrade's 4 1/2-in.-diameter depressed-center wheel grinder features a 12,000-rpm, 1-hp air motor for cleaning metal before welding and removing weld beads afterwards. This grinder has a safetylock throttle and grip-traction side handle that increase safety and reduce hand fatigue. A rearexhaust inlinemuffler assembly reduces sound levels to 78 dB (A).
Dynabrade Inc.
Clarence, N.Y.
dynabrade.com
